Connecting LC-1 to HP Tuners cable
Mod with training wheels
Did a search on this site, nothing. The help file in HP Tuners shows a cable that I don't even have, so I'm not sure how to connect it. The only spare cable from the LC-1 is something like the 2.5mm audio cable for cell phones:
http://www.uxsight.com/product/image...032090909c.jpg
How does this connect to the scan cable? I've got the little green connector, but no idea what needs to plug into it.
http://www.innovatemotorsports.com/s...C-1_Manual.pdf
You must have got it used and didn't get a cable?
Wiring it to the PCM is a cool idea, but it sounds even more complicated.
I got the software and hardware all new. There is another 2.5mm to serial cable, but I can't use it because the scan cable only has the 8 pin green connector, and my laptop doesn't have a serial port. In fact I haven't seen a newer laptop with a serial connector in some time...
Page 4 of the PDF says you have an interface and power cable with 6 or 7 stripped ends, and it tells you what they are. Go to step 6 on that page. The yellow or brown wire go to the green HP Tuners plug.
I just did this with an LM-1...if you are changing the settings in the LC-1 using a serial cable you will have to change the serial settings/speed.
The you'll have the head phone jack, one wire gets put into the green connector for your HPT, and the second gets the ground in the green plug, I think it the last one.
Then you'll have to set up your wideband inside HPT and make sure its reporting the correct value: great link for how to set up wideband
