Crank relearn??
Crank relearn??
What type of program does the dealer have that does this? Can EFILive do it? or HPTuners? And one other thing...Does anybody have a good idea what is the safest amount of TM that can be removed and still be able to tow? By towing, I'm talking about maybe 3,000lbs...(2 jet skis on a double trailer)??
i spoke with allan nelson...concerned about the same TM thing. I pull a 24ft boat durring the summer. I have the 4L70E trans which has some extra hardened parts, but otherwise still a 700r4 type. He said leaving 20 or 25% of the TM intact is still a good cushion. They can also keep 100%tm when you push the towl haul button. For a little trailer and some ski's i wouldnt worry.
Originally Posted by BigBlackAv
how do you do a crank relearn w/ HPT?
CASE Learn: To use the CASE learn function please follow these steps:
Put the vehicle into park (auto) or neutral (manual).
Turn off all accessories and A/C.
Apply the parking brake.
Press the brake pedal. Keep the brake pedal depressed during the entire procedure.
Press Begin.
Gradually rev the vehicle to fuel cutoff (around 4000-5000 RPM's) over a period of about 4 seconds. When fuel cuts out, immediately release the throttle.
Allow the engine to come back to an idle.
Turn the ignition off for at least 15 seconds. This step is required for the VCM to store the newly learned configuration.
