Crank Relearn scanners???
Old 09-18-2005 | 10:40 AM
  #31
Scott Mills's Avatar
Can anyone in the Tulsa area do a re-learn on my truck?
Old 09-18-2005 | 11:00 AM
  #32
NoChrome's Avatar
The only reason you should need a relearn is if the motor was started with out the stock pcm, or if you called up jesse and had him send you a new one while you drove around on your stock pcm. The pcm remembers the last crankshaft position and if it moves or changes without the pcm knowing about it you will need the relearn.
Old 09-18-2005 | 11:11 AM
  #33
Need a re-learn due to a p0315 code and my new PCM from Nelsons.
RustyD
05-23-2016 08:04 PM
SSpeeDEMONSS
10-03-2015 09:21 PM
Cammed4ever
09-30-2015 04:38 PM
trxmxzx
09-29-2015 08:42 AM
