DBW pedal is 100% WOT at 1/2 pedal travel
#61
That was the conclusion I came to as well. EAP pedals are definitely shorter thow, I haven't seen a fixed pedal with the short throw, but I haven't looked at many.
I'd still like to know if it's the TAC or the ECM that's setting the amount of available pedal travel. But there are still several out there that have pulled all the parts themselves and have experienced a mis-match issue.
![Icon Confused](https://www.performancetrucks.net/forums/images/smilies2/icon_confused.gif)
#62
I'd still like to know if it's the TAC or the ECM that's setting the amount of available pedal travel. But there are still several out there that have pulled all the parts themselves and have experienced a mis-match issue.![Icon Confused](https://www.performancetrucks.net/forums/images/smilies2/icon_confused.gif)
#64
all-in-all though, i have mostly had the shorter throw pedals. so that is why i didn't have a problem welding the stop on, as i figured that is the throw that most people are used to. i was a little concerned that it may feel like the pedal is sensitive, especially off idle, but hasn't seemed to be an issue.
#66
I don’t know whether or not if it may be the answer to some of you fellows issues, but for those whom haven’t seen them, Lokar has a programmable electronic peddle assembly available for some DBW applications. The application list may not include the year model your dealing with though.
http://lokar.com/product-pgs/new-pro...e-by-wire.html
#67
I talked with the parts guy at the salvage yard about this. He said my assembly came out of a vehicle with non-adjustable pedals (04 Avalanche) and that I will need solve the problem with tuning.
#69
While visually, it appears that the '98 corvette pedal has less overall pedal travel from off-throttle to when the metal tab hits the base, my TB is still 100% WOT at half of it's travel too ![Icon Lol](https://www.performancetrucks.net/forums/images/smilies2/icon_lol.gif)
The corvette APP sensor did not respond with my TAC and PCM. Not sure if the sensor was faulty, or if there is some other type of mis-match there.
The lid on this case needs to be blown off by someone.
What piece is at fault???
#70
I just did one today that at 100% pedal only gave me 50% throttle (backwards of what usually happens). So, off to the "pile" of pedal & tac modules to try a different one. ended up using one of the plastic pedals with short throw.
I need to start logging the pedal parameters in the tune for each one i do to see if any difference. but honestly, i think it is in the tac, which we have no adjustability on.
