Denali 6.2 WOT Problems
It has got to be throwing some codes. What do they indicate? If you have changed something like the crank or cam sprocket from a phasing type to a stationary type, you might need to disable the phasing diagnostics or do a crank relearn.
only code im getting is for the cam timing over advanced...
im starting to assume it might be something to do with the trans since it only happens in first gear?
other ideas are maybe the cam install... when I'm at idle and rev the motor i get 7 hits of KR... its loopy...
I reduced the timing down and same thing...
my mechanic told me it looks like a safety feature for the engine.. will be taking out the vvt and installing a normal cam in the near future...hopefully this should take care of my problems
What is the sensativity at in the KR table? My SSS had a lot of false knock at the top of first gear and it fell on it's face before the 1-2 shift. My first thought was KR when I watched the video but with all your guages going loopy I wasn't sure.
im getting no KR on the top of any gear.. can't tell on the 1st gear since it won't let me read till the end of it.... just plenty of kr at idle....
i haven't played with the settings, and this is deffinately something new...
just ordered an ls3 timing cover off ebay, hopefully a new better cam will fix the problem..
