E38 SD tuning
E38 SD tuning
Spent a little time reading about the SD tuning for E38 ECMs, and wow, what a mindfuck. The days of simple VE tables are gone. GM uses something called zone mapping coefficients that determine how much fuel to deliver to the engine. But the only way to get these coefficients is to use a number cruncher program called MATLAB, or another 3rd party program called EQ VE3, which is equally confusing.
I know its a long shot to ask, but has anybody had experience with this yet? If ever there was a dark art of tuning, this is it.
FormerVendor
Just have the tune you are working with and the program open at the same time, open all of the coefficient tables in the tune that it requires, copy coefficients into the program, it spits out the VE table in the program. Log plotting lambda/AFR error against VE, make changes to the VE table in the program based on the AFR error you logged and then generate equations, send equations back to Hptuners tune file with all of same coefficients tables open and their will be the changes. As with any airflow mapping repeat until error is within 1%-2%.
JFortner5
08-20-2015 06:13 PM
oharajo
07-18-2015 09:24 PM
