ECM Pin location
Old 07-20-2005, 10:13 PM
How do I change this text
Wilde Racing's Avatar
So the ECM controls the ground on both fan setting right?
Old 07-20-2005, 10:16 PM
LS1Tech Sponsor
wait4me's Avatar
yes that is correct.
Old 08-21-2005, 09:07 AM
aklim's Avatar
Does this mean you have a harness for fan activation to make it work like the stock version instead of what Nelson does?
Old 07-24-2006, 12:52 PM
TTT do to PIN 33 is already used up on my truck.... I really need to find out the other pin location for the fans.........
Old 01-04-2007, 04:18 AM
Blown02Sierra's Avatar
could the unused pins be used for inputs for wideband afr, fuel press., egt, dual tune, valet mode, nitrous, et cetera? What about outputs for certain gauges?
Old 01-04-2007, 07:58 AM
Resident Retard
BlackGMC's Avatar
It is my understanding that the Pin 33 only works on 03+ PCMs.
Thread link read from page 7-10
https://www.performancetrucks.net/fo...=blowing+relay
GM Factory Efan wiring harness, dual speed.
15216055
i hope that helps
Old 01-04-2007, 08:31 AM
That may be an option..
Blown02Sierra, you are 100% correct..
This thread is abit older, I bought a aftermarket fan controler and temp sensor to control the other setting...
Old 01-04-2007, 08:36 AM
Resident Retard
BlackGMC's Avatar
Sorry i did not even notice the dates...
Old 01-04-2007, 08:58 AM
Nick™'s Avatar
People are already using the wires for the egr they are removing for a wideband feed, which can be read through HP Tuners without the enhanced interface.
Old 01-04-2007, 09:28 PM
Well, i never had egr and i'm using efilive. Is that still an option for me? And what about the open pins? Also, can my 02 pcm use pin 33 for the hot setting>?
Quick Reply: ECM Pin location
