EFI Live injector slope adjustment question
You will first have to determine exactly which injectors you have. Then recalculate the IFR at your base fuel pressure(vac ref disconnected from FPR) if it differs from the FP at which the new injectors were rated. As stated, your IFR table will have the same values across the board.
You should also change the voltage offset, etc. tables if that data is available for the new injectors.
Definitely correct the cylinder volume for the new engine and bump up the VE table(s) to be safe if running SD.
The real tuner will have to do this cause that was chinese to me.
