efi live and tow/haul button
Mods: can you move this to the tuning section please? Thanks
Ok, i have never had a tuner before but i will be buying efilive this year. My question is can you program the tow/haul button to be a performance mode instead of a haul mode. like can you change timing, shift points, etc for it and then run an everyday driving style when its off. i will also be running a built 4l60e with 3200 converter. thanks ahead of time
Bryan
Bryan
Yes you can. The tables you adjust are called Performance. Those are the tables that are used when you press the Tow/Haul button.
You can adjust the shift speeds, shift firmness and TQ managment as well. You will not be able to adjust any engine parameters like fueling, timing, etc though. It only works for the trans tables.
thanks Zick, thats exactly what i was wondering. imaging how cool it would be if you could modify all the other tables too...you could have a dr jeckyl and mr. hyde truck
![Cool](https://www.performancetrucks.net/forums/images/icons/icon6.gif)
Yes you can leave the Tow/Haul ( Transmission Performance Mode tables stock) and it will work like it does now with Tow/Haul mode activated. The problem is some of the general switches and constants that you can change can affect operation in either Tow/Haul setting so you will want to think about the effect they will have on your truck's operation when towing before you change them. The main ones are Abuse Mode, PWM ( Positive Force Motor Current Table and Negative if you have one ) and TM. Any changes you make to these will in most instances affect both Tow/Haul mode settings.
lxcoupe
09-23-2015 12:11 AM
supershift67
09-18-2015 08:21 PM
