Efilive PID's
It depends on what you are interesting in looking at... I've probably logged up to 75 different ones depending on what I was looking for. My LS1B PCM supports just over 300 I think, not including calc pids I've made. The rule of thumb is to not log more than 24 at once or else the sample rate (frames/sec) will be low.
I can give you a list that BBP had me log if ya want send me an email to shaw_426hemi@hotmail.com. Or you can go to his site and check out the list he recommends for data logging. But as posted it all depends on what your interested in looking at.
9 Second Club
As said a couple of times, it depends on what you are looking for. I generally have different groups of pids that I use - for open loop speed density tuning with a wideband, open loop MAF tuning with a wideband, idle tuning, closed loop fuel trim tuning, transmission tuning... and as said, don't log more than 24 channels at once.
What are you looking to do tuning wise? that may help to tell you what to log...
Here is the list of PIDS that BBP wants: https://docs.google.com/document/d/1...aKw6UnZug/edit I'm having trouble finding them all and loading them into my flashscan for logging purposes. Specifically, I can't find power FW and Power RW. Apparently they should populate after I start logging data.
I think I got them all set up in my flashscan now, minus the two calc values above. It shows that all my channels are allocated (blue and green boxes in V8/scan tab), so I'm not sure that it would be able to log those two also...
Tydriver
45
10-23-2015 09:19 PM
supershift67
09-18-2015 08:21 PM
Black02SS
05-14-2006 02:26 PM
