EFiLive vs HPT ... owners of both, I need opinions
#22
Resident Retard
another question... when this problem occured did you switch to a different OS? Your currently running OS 12202088, and I could not find a stock/base file for that OS on holdnecrazy...
Also if i read your previous post correctly, you had a engine fire? is that correct? did you get a new engine hareness/computer? If so what year model truck did it come out of???
#23
No the engine missfire was something else... but its all good...it was a bad wire to a fuel injector...pulled it recrimped it...no more misfire.
The Fan problem happen with my stock PCM OS then i switch to this new PCM with the 6.0 /4L80e on it so it was easier to tun.... but the problem existed pre PCM swap
#28
Yes definitely... but the problem with my search results is that they arent the same issue. Here in this link you can see he is talking about air temps in the cabin... I have no issues with my air temps.. hot or cold.. they work
#29
The thing is also i dont know where to even start looking for HVAC modules or anything...I need some quick direction cause i believe this has something to do with it,I just dont know where to start
