Excessive water/steam coming from exhaust pipe truck runs crappy. What could it b?
#22
Joseph- I did torque the headers to spec but I did read somewhere that the stock gaskets are better than aftermarket so I might throw the originals back on an see what that does. I heard you can reuse them but I don't know how true that is. WHat do you think. If that doesn't remedy the situation, I guess next order of operation would be to pull the valve cover and check the torque of the rockers?
#24
I am currently replacing the header gaskets with the factory gaskets. I forgot to mention yesterday that the oil pressure was fluctuating between around 30 and 60 yesterday with normal driving.
I also stumbled across this thread about an o ring that may go bad:
https://www.performancetrucks.net/fo...essure-361346/
#28
Custm2500's Rude Friend
The factory metal ones are far superior and are reusable. The only down side is the head and the mating surface on the header must be flat in order to make a good seal. You must also tighten/torque the bolts properly as well. The fiber type gaskets are more forgiving if there not flat but break down over time.
As far as oil pressure that's not far off from normal when the engine is warmed up especially with the heat from the supercharger.
Suburban2500
07-13-2015 09:57 AM
