F terminal code???
F terminal code???
What causes the F terminal code???
I upload a 2001 file to a 2000 silverado to eliminate the secondary VE, but the code F terminal pops up and the light of the battery flashes on the dashboard.
Custm2500's Rude Friend
99-00 only uses the L terminal for the charging circuit
01-02 Uses both the L terminal and the F terminal
I believe you have to turn off/ Disable the F terminal in the tune under the platform options and then turn the P1638 in the engine diagnostics from Non Emissions to Not reported under DTC process enablers or what ever HP tuners calls it, This might Fix your issue.
TOTM: January 2007
Because the charging circuits are different on the 99-00 Vs. the 01-02 operating systems.
