Fast Blinker Bypass
Fast Blinker Bypass
My turn signals are blinking fast. It is not a bulb, I know why its doing it but its a long story. Is there any way to reduce the load on the circuit to stop this? Could a resistor be used or something to that effect?
I added pwr fold mirrors and replaced the BCM with one from a Escalade. The SUV brake signal is sent differently through the BCM and I had no brake lights on my truck except for my high mount. In order to keep from buying a new BCM I tapped into the high mount signal. Now the voltage is off and the blinkers blink fast. A $200.00 BCM will fix the problem, but if there is a way to fix it simply Im all for it.
Baltimore Whore
Resistor.. Used for when people upgrade to led blinkers, it holds the voltage out, because they use some much less then a reg light.. Should work for you in this case
murderedSS
27
10-12-2015 11:13 AM
whitelazer
09-22-2015 09:38 PM
