First to Market, 2014 GM truck tunes!
Old 07-27-2013, 12:47 AM
  #21
gamble686's Avatar
Originally Posted by Mike@Diablosport
What footprint are you referring to exactly?
We have done our homework on this. We have confirmed time and again that we do not alter/change/edit anything to do with the CVNs, which is what GM advises dealer techs to look at to determine if a vehicle has been tuned.
We leave no trace of having been there
Every time the tune is pulled or reflashed it leaves a history of it having been removed and replaced unless it can someway be made to appear as though it was done with a dealer tool. I am not saying they will notice it, but if they look hard enough it can be found.
Old 07-28-2013, 11:57 AM
  #22
CodyG's Avatar
I just ordered my InTune, Ill leave some feed back when I get it in a week or so!
Old 07-28-2013, 07:52 PM
  #23
yzriders182's Avatar
GM has a flash counter so the dealer can see how many times the pcm has been re-flashed. If a high number is in it, it raises questions....
Old 07-29-2013, 11:34 AM
  #24
LS1Tech Sponsor
Mike@Diablosport's Avatar
Originally Posted by Area47
GDI engines tend run an average of a point leaner than port injection. In all of the ones I have personally calibrated, even under 22+psi the average afr is 12.16-12.8 on gasoline. Running high 11's low 12's on a gdi setup is going to cause an injection timing issue and possible misfires. At least in my findings.
Did you happen to notice the factory AFR on the dyno sheet I posted ?
I would imagine GM knows what they are doing when they set it to run as rich as they did
Old 07-29-2013, 11:35 AM
  #25
LS1Tech Sponsor
Sounds like you are talking about the CVNs, which we do not touch
There is no law against having your own TIS subscription and flashing your PCM every day if you want. That is not grounds for warranty denial by any means
Old 07-29-2013, 02:11 PM
  #26
Area47's Avatar
::fp::
zo6freak
14
10-18-2015 06:43 PM
wrb002
08-31-2015 12:00 PM
black6spdz
07-16-2015 01:32 AM
hackrst
07-11-2015 11:17 AM
Quick Reply: First to Market, 2014 GM truck tunes!
