fuel trim difference
What is an acceptable difference between banks 1 and 2 for the fuel trims? My bank one is sitting at +1.6% and bank two is at 0. I thought this was a little much but wanted to know what yall think. I think I might have an exhuast leak but I cant find it anywhere, I've searched every inch of the trucks exhaust with it running.
Chris
Chris
Yup, its all good. Like Crash said if it was way lean look for a vaccum leak. But If you think you have an exhaust leak.Try tranny fluid in the main vaccum line it smoke like a **** and will be easy to find.
Mine are always in the negative and different. -0.8 and -8.5 once I get into the higher rpm 4K+ they both go to 0 and then when i let off the go negative and are off by 6 to 9 points.I've been told leaking injector or exhaust leak or ignition problem. What do you guys think?
Originally Posted by 1slowsilverado
Has it allways done this or just started? Who tuned it, Can you post or send a log file?
Is it still leaking though? Sounds like that might be the problem. But let me take a look at the log and tune. Timrichardson@cfl.rr.com
GXPJAY
02-13-2022 09:15 AM
05GMC4.8
08-07-2015 10:55 PM
InsaneDomestics
07-27-2015 03:42 PM
banker099
07-04-2015 06:50 PM
