Full rewire
During my LS6 swap we pulled out my engine harness lengthened and shortened accordingly and ran it down and around the back of the motor. I really like the way it turned out. Be sure to solder and heat shrink all your connections so you don't have any issues down the road.
I been there before, relocated Ecu and Tcm inside the cab. I don't know about older style cab if the fuse box any different than nnbs. It not that hard but its time consuming. On 2007 nnbs the fuse box has plugs that disconnect from underneath basically the ecu and tcm are connected in same wiring harness and rest is body wiring headlights & etc.
Buy a Labeller and Helping hands You Thank me later
Label the wire twice and check twice then cut the wire in between.
Do it one by one because there is allot of of wires that look alike. Good Luck and keep us posted
On the Link below pg7 you see what you have to deal with Ecm & Tcm Only
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
Closer_2001
09-24-2015 09:15 PM
