Gen 4 limiting as a Gen 3, help!!
Old 06-11-2015, 11:08 PM
elir_mn's Avatar
Originally Posted by AKlowriderZ71
What tuning software are you using?
HP Tuners
Old 06-11-2015, 11:15 PM
elir_mn's Avatar
Originally Posted by RS/SS 4.8
Let me see. My 07+ truck when u hit the limiter that is now long gone for example at 97mph it would cut fuel till it slowed down till 90mph then go full force again. Im guessing the nbs just holds 97mph kinda 2stepish?
No my friend, is that I did not understand well, speak RPM limiter I want to limit the engine as if installed Rev 2 step, as does a Gen 3 system
Old 06-11-2015, 11:29 PM
elir_mn's Avatar
Originally Posted by Jeebalow
got in touch with the OP, I'll be translating best I can.
He's asking about a rev limiter. He is using HPtuners and wants the gen IV to rev limit like gen III by cutting fuel.
elir, dice Pat (03sierraslt) que cambies el retraso. Muevelo hacia el cierre. No se de que retraso o cierre esta hablando pero tal vez tu entiendes.
Dile que no cuento con ese parametro que voy a subir una imagen con los parametros que cuento para ver si me puede ayudar en lo que quiero
Old 06-11-2015, 11:32 PM
elir_mn's Avatar
Here the parameters I have
Old 06-11-2015, 11:48 PM
Jeebalow's Avatar
Change the delay. Make it closer to the cutoff.
Are you referring to the switchover delay? Just make it closer to the extreme cuttoff?
tal vez se este refiriendo al switchover delay, que aparece cuando seleccionas eso? Si es eso, intenta cambiar el switchover delay mas cerca al numero en extreme cutoff
Old 06-12-2015, 12:11 AM
elir_mn's Avatar
Ya e movido ese parametro y no e tenido resultados, aunque tengo que volverlo a probar, ese parametro hace que despues de unos segundos (dependiendo los que pongas) cambia el metodo de limitacion de Fuel/Spark a ETC
Tendria q volverlo a ajustar para ver
97_ek
09-23-2015 09:16 PM
elir_mn
09-19-2015 11:43 AM
FlowmasterMufflers
09-11-2015 03:32 PM
chvy=power
09-08-2015 11:06 AM
chvy=power
09-08-2015 10:59 AM
Quick Reply: Gen 4 limiting as a Gen 3, help!!
