Grams/Cyl....What's "normal" for an H/C 6.0??
I see an upper limit of .80 Grams/Cyl at my estimated torque peak (4800rpm), I know because of the hotter temps now I'll actually see higher numbers during the winter (I just started REALLY paying attention to this lately...mostly due to the SD tune I'm now running) but what is a "normal" upper range for an H/C 6.0
not to steal this thread....
but what exactly is Grams/Cyl??
I see its on the Timing Tables... set the spark advance with the RPMs and Grams/Cyl..
im not exactly sure what the Grams/Cyl is?
is it predicted??
is it predicted??
Grams/Cyl = number of grams of air that each individual cylinder is getting per combustion stroke....doens't sound like alot, but figure out how much 1 gram of air weighs and the volume of that amount of air will really suprise you
Moderately Differentiated
AHH, i wasnt exactly sure what it meant....
So with a CAI or Ram Air, at higher speeds, would it force more air into the motor??
A RAM, a real RAM will essential jam the air into the air trac as you go faster...again making it alot easier for the engine to get the air...volume of air.
Neither will probably increase the actual amount of air the motor is taking in the ultimat end. Just frees up restriction. You may see a bump into next MAP line.
![Cool](https://www.performancetrucks.net/forums/images/icons/icon6.gif)
Grams/Cylinder = (MAF in G/S * 15)/RPM
So you log your MAF in Grams/second and multiply by 15. The result is divided by the RPM logged for the given MAF reading. If your logging software records data in grams/Cyl then this is the formula it uses to calculate the result that you see.
Hello Dave
Originally Posted by Zick
Right now I believe I am also hitting .80 g/cyl.
