Hard cold start on E85
I would start in the 0 and 1 stages, from -40° to 158°, and multiply them by 1.25. Then blend into the higher stages. If that doesn't help, then multiply the same temperature ranges in the 2-12 stages and blend upward again. It's all a guess. You won't hurt anything, but save your changes with a different name than your present tune so you can put it back if you don't like it.
FormerVendor
GM has used Virtual Flex Fuel Sensors since 2006 on must E85 applications.
I perfer using OE E85 calibration on all applications for tuning. If you use a VFF calibration you need to take a lot of time with this tune. You can run into an issue with the tune being off and the PCM uses the VFF software to correct the stoich for E%, but it is the tune that is off not the E%.
On your 08 all you need is a E85 calibration setup for your VCM ID and VIN. Then you will have a calibration that works like the OE truck. You can tune the normal HPT tables after that.
email me your VIN and I will look around
caleditor@pcmcalibrators.com
