Head scratcher...Tune "Fan 2" for A/C only?
#53
Ah, cool. The only thing i'd be worried about with your setup is that I never trust anything that drops voltage like rheostat's and resistors. They never seem to have much life and I know how important reliability can be on a trail truck. I really admire your idea's here though.
Bottom line, if I'm out on the trail and the fan gets wet and fails, I have to get to the nearest highway and cruise to safety and I'll be perfectly fine.
I just don't want to think about that. Like I've been talking to nonnieselman about on AIM, my 18" fan is a BEAST. It spikes 100 amps at startup and draws a constant 33amps running 14.1 volts, which is why I upgraded to a 280-300amp alternator and dedicated an Optima Yellow Top to solely power the engine/fan. I have a 2nd Optima battery for my winch. This is why I'm trying to utilize a LOW speed and HIGH speed, so that I'm not drawing 33amps and pulling 5500 CFM through the radiator if the engine just gets a little warm. It's a serious fan, it is the strongest fan I could fit in my little Sonoma's engine bay.
#56
Hello Dave
They've got just as much control as the 03+, but on trucks, J2(red) pin 33 is being used by the auto-recirc function. HPTuners would need to add the ability to change that pin's output control. It's there in the PCM, you just don't have access to it (much like the A/C fan settings).
J1 Pin 42 is always the blue harness.
J2 Pin 33 is the red harness in 99-02 truck, green in 03+.
#57
How do I change this text
#58
#60
Russ Kemp over on HPTuners forum provided me with this. Just glancing at it the first go around, it doesn't look like I can wire this fan up like Lincoln does from the factory without that controller, so back to the drawing board.
Gahh I just want to go home and test the fan, why do I have to be so far away from home without a vehicle?!?!?!
What do ya think?
http://www.hptuners.com/forum/attach...4&d=1222272436
What do ya think?
