Head scratcher...Tune "Fan 2" for A/C only?
#83
Ok you can take it off the net now. ROFL I saved it, thank you. I will draw it up in Paint and see if I can clean it up a bit.
You have been a huge help, Wilde Racing. If I'm ever in your area or you're ever in MN I owe you a case a beer.
Edit: Just found new info.
#84
Hmm.
Wilde Racing I just found this.
Post #45, then on.
https://ls1tech.com/forums/showthrea...=768900&page=3
Post #45, then on.
#88
Do you have a relay in mind? I have my Bosch 75A relay, but since I need another I can just pick up 2 of the same kind if my 75A wont work. I noticed mine does not have 87A...just 87. On high, the fan spikes above 100A and runs continuously at 33-34A so at least the high relay has to be up to snuff.
I will be back to check this in about 5 hours. Gotta drive back to school now.
#89
How do I change this text
Ya, you can always use the diagram you posted.
The heavy duty relays for number 1 and 2, and a standard relay for number 3.
#90
Since when does it take 5 hours to make that drive Inch? And wow does this bring back some bad memories. I have made a fan capable of being turned on by an electric signal but bypassed the current problem and made manual adjustable speed fan by using what you would call a resistor pack (think how your HVAC in your car works.)
