This heat is ridiculous!
Oh, and the pictures are from torquescan. Its an app for android. Pretty nifty.
Ive never seen temps that high even when im idling for 30-45 min with the AC wide open and was 103-104 my mirror showed.
Im in no big hurry to put my turbo on with this kinda heat. It was 85 this morning when i got up at 5am. Blah......
formerly 98wytebord (3-14-2012)
I have the same thing. You download the app on your phone called torque and I got the blue tooth device from ebay that connects to your phone. It's pretty neat and I paid like $15 for the blue tooth piece. The one I have is made by vgate scan. They say not all brands will work but mine does fine.
Ditto on the adaptor from eBay. Search elm327. It plugs into the obd port and transmits to your phone via Bluetooth.
This log was taken after about 10 minutes of 45mph driving then a stop at sonic for maybe 5 minutes. Ambient temperature sensor in the mirror has showed 110+ all day.
What intake are you running? The IAT is believable if you've been idling stopped for 5 mins in 110F temp. Using the stock air box or one with a scoop into the wheel well should help a lot. If you have an open filter where the stock air box was you will see high temps unless you're moving.
I haven't actually did it but if you go to where it says realtime info click on that than go to menu hit more than it gives you the option for share screenshot and many ways to send it. This is on a HTC inspire phone but should all be the same with the app. Hope this helps.
