help with codes P and B in 5.3
hey guys i need help whith these 2 codes thave been on and off since i put my JBA's in in nov 05and put my truck in the river on may long of last year
the codes are P0157 and B2615
thanx
thanx
DTC B2615 = Passenger Compartment Dimming 2 Circuit
This is a BCM function trouble code, I would image. No tuning solution can delete this code, may be able to clear it though.
DTC P0157 = HO2S Circuit Low Voltage B2S2
This would be a bad or failing oxygen sensor on the passenger's side, behind the cat.
ya the b code was the light in the pass door came apart, and ill check the o2 this weeken but it only turns on when im on the gas after about 80mph and haul'n ***. but thanx
97aztecgt
08-13-2015 02:11 PM
rojeho
08-08-2015 07:20 PM
05GMC4.8
08-07-2015 09:55 PM
