HELP! Doesn't return to idle in drive, "cruise control"
Old 08-10-2009, 12:30 AM
zippy's Avatar
It's not going to hurt anything. Just try putting that back in to see if it helps. That's just the first thing that jumps out at me and is often the cause of what is happening.
Old 08-10-2009, 12:40 AM
0235SS93's Avatar
Ok thanks! I'll let you know how it goes...
Old 08-10-2009, 09:10 AM
krambo's Avatar
Originally Posted by zippy
Your base running airflow is too high.
I tend to agree.
You originally stated that the idle / tune was good for a week or so and this just started happening correct? Did you do any other tuning during this timeframe such as Ve or MAF? If so, you could have changed the amount of Base running Airflow your motor requires.
I would lower your Adaptive Idle RPM, Min ECT to around 150 as well...assuming you have a cooler than stock thermo.
Old 08-10-2009, 12:00 PM
0235SS93's Avatar
Zippy, you're the man! Lowering the base running airflow fixed it! Thank you!
Old 08-10-2009, 09:47 PM
zippy's Avatar
Very nice. Glad to hear I could be of help.
Old 10-13-2010, 06:07 PM
Where's the Beef?
viciousknid's Avatar
I don't see a Base Runinng Airflow table for the 99 i'm tuning. Is it the same as Desired airflow B4307? Or should I first try Throttle Follower Airflow B4315?
Old 10-13-2010, 09:31 PM
FormerVendor
KLUG'S SS's Avatar
Yes the Desired Idle Airflow is the same thing
TX Tahoe Z71
09-01-2015 09:11 PM
Mossyoakglock
08-28-2015 12:49 PM
ZO6Ted
08-12-2015 07:50 PM
noproblems209
08-10-2015 06:57 PM
GreyChevy
07-07-2015 08:57 PM
Quick Reply: HELP! Doesn't return to idle in drive, "cruise control"
