help with new delph 42lb
Old 11-06-2008, 03:46 PM
53RUSSELL's Avatar
Default help with new delph 42lb
I have changed my IFR and voltage table for injectors and still running lean at idle around AFR +17. I started redoing my v.e table and my number were a lot high than before. Please let me know what you guys think. Can log you pid in EFIlive to voltage at the injector?
Thanks guys
File Type: tun
Old 11-06-2008, 04:30 PM
charcold-bowtie's Avatar
If it seems uncontrollable and random, plobly ripped a O ring putting them in. I did the same thing let me see if I can find my old thread.
FYI my oring looked fine but a new set fixed the problem...
Old 11-06-2008, 04:45 PM
53RUSSELL's Avatar
I put some lube on them before putting them. The a/f stay same unless i get the vacuum close to 20 and a/f will drop close to the command a/f. So I'm leaking air around the injector?
Old 11-06-2008, 04:47 PM
Thats my guess, even if the IFR is close it shouldnt be that bad, especially after a little ve work.
Obviosly leaking on the botom of in injector, if it was the top you would have a gas leak.....
Old 11-06-2008, 04:56 PM
Mort's Avatar
The only thing I had to change in my tune to run the 42 - 44 lbs injectors was the IFR table. I notice mine is lean as well at idle under COS3 but does it really matter?
Old 11-06-2008, 04:59 PM
53RUSSELL's Avatar
I read your thread its simlar. with new injectord it's leam unless i put foot on the gas rev to about 1200 and let vaccum get close to 20 and a/f is great. So i'll stop by the dealer and get new injector o-rings and trt it again.
Old 11-06-2008, 05:02 PM
53RUSSELL's Avatar
MIne lean at idle and driving truck around the block and yes that bad.
Old 11-06-2008, 05:36 PM
hirdlej's Avatar
You don't need to monkey around with the voltage offset, I don't understand why people do this. I just changed the IFR table for mine and my AFR idle is perfect at 15.1:1 Who told you to change the voltage offset?
Old 11-06-2008, 05:55 PM
53RUSSELL's Avatar
Only change it trying to get the a/f to get back in line. When left stock my a/f was in the 20s. Now that changed a/f is in the 17. I'm just trying to fix the problem. If have any ideas on this let me know.
Old 11-06-2008, 06:28 PM
hirdlej's Avatar
I can't open .tun files with HPT but try this for your injector settings. I have 62PSI of fuel pressure at idle and this is what I used.
Quick Reply: help with new delph 42lb
