hesitation/misfiring after first drive everyday
Old 08-18-2006, 11:49 AM
Toaders's Avatar
$225 for an intake manifold gasket? Thats alot of moola! When i replace my knock sensors they where only like $50 bucks
Old 08-18-2006, 12:18 PM
blownerator
BlownChevy's Avatar
Labor included with a warranty. Thats what we charge.
Old 08-18-2006, 12:23 PM
Toaders's Avatar
Oh installed! I get it.
Old 08-18-2006, 12:26 PM
hourang's Avatar
Originally Posted by BlownChevy
you can get them from the dealer, or even autozone might have the felpro gaskets now. 225.00 is what we would charge here.
Start the truck when the engine is stone cold and spray some carb cleaner around the base of the manifold....if the idle changes thats your culprit.
ill do the 10minute job myself. ill try the carb cleaner test. thanks.
Old 08-24-2006, 10:09 PM
PT's Slowest Truck
budhayes3's Avatar
Check and make sure that your fuel pressure regulator isn't leaking also...it's located in the center of the driver's side fuel rail. Pull the vacuum hose off of it and make sure it's dry. If there's fuel in that hose, the fp reg is leaking and needs to be replaced. A leaking fp reg will cause the vehicle to run rich and give it a flooding type of condition after it sits and is cranked over.
Old 08-25-2006, 08:21 AM
hourang's Avatar
hrm that makes a lot of sense. i will check that out as soon as i can, thanks a ton!
someotherguy
11-08-2017 06:46 PM
06 4.8
09-11-2015 10:36 AM
MA$TER_E
09-09-2015 03:14 PM
jleews6
09-08-2015 10:17 AM
mayko
09-07-2015 12:24 PM
Quick Reply: hesitation/misfiring after first drive everyday
