how to correct going rich on decel
#21
9 Second Club
EFI Live only made this available in the CAX file as B9021. HPT has this available as the minimum fuel milligrams. I did not discover this, I was directed down this path by a fellow PT user that deserves the credit. I just decided to spend the credits on HPT to try to change it and it worked. I love EFI Live, dont get me wrong. I love the COS, but EFI Live needs to understand that there are plenty of people using their software on the 02-07 OS's, and they need to address this issue.
His minimum fuel milligrams is already pretty low, but I would also recommend cutting it in half and seeing if that helps the situation. Go to engine/fuel/transient/min fuel milligrams and half it...
#22
so for anyone having this problem, i halved the min fuel milligrams this morning, took a little ride, and it's definitely fixed the problem. dfco is leaning it on out now on decel. think i'll turn off the dfco temporarily so i can finish tuning the ve table.
#24
yea the injectors are 106.7 lb/hr at 58psi. i don't see anything wrong with going to .014, it allows the injectors to go down to 1.5ms now, which allows dfco to kick in on decel now and do its job instead of everytime i let off the throttle it immediately going to 11.0-11.2
#27
In your first post you said you are running the FIC 80lbers. I'm running the same injectors and have the same exact data in my tune. If they are rated at 80lb/hr at 3 bar, then they flow 92.4lb/hr at 4 bar. So are you running the FIC 850cc or FIC 1000's?
Just wondering because if they are sending the same data out for different size injectors, I won't be too happy.
#29
well i just looked at the injector data.. i told them i wanted 80lb injectors.. looks like i got 92.4lb injectors though. they're 850cc. 92.4lb at 3 bar.. 106.7 at 4 bar
