How do I convert my 06 silverado from DBW to Cable drive?
Old 05-05-2010, 05:06 PM
11 Second Club
Phantom's Avatar
talking to wilson as we speak...
Old 05-05-2010, 05:14 PM
Resident Retard
BlackGMC's Avatar
http://forum.efilive.com/showthread....ighlight=g1207
Old 05-05-2010, 05:21 PM
TX Tahoe Z71's Avatar
Originally Posted by Phantom
its a little different when your FORCING the air through it...
Very true, but with over 600hp at the fly, I was assuming he was FI
Old 05-05-2010, 06:01 PM
Pontiac Derek's Avatar
You can do it with DBW and a Vic jr they make elbows but again your stuck with the GM TB, and figuring out any pcv, map, and other things, might be a better band aid than whats out already though ,I'll probably just end up with a FAST setup or I'll find the limits on the tbss intake LOL
Old 05-05-2010, 06:03 PM
Resident Retard
BlackGMC's Avatar
Excellent thread to follow, this guy has done it...
https://ls1tech.com/forums/conversio...onvertion.html
some other supporting threads...
https://ls1tech.com/forums/conversio...v-hwd-nos.html
https://ls1tech.com/forums/conversio...onversion.html
so in short it looks like it can be done!
Old 05-05-2010, 06:08 PM
GMCtrk's Avatar
I've seen nick williams 92mm and 102mm DBW TBs. Warning: they're pricey as hell!
Old 05-05-2010, 06:21 PM
Praise The Lowered
RibeiroBJJ's Avatar
Nick Williams makes 92mm/102mm DBW throttle body's available through scoggin dickey...IIRC they are $509..not too bad
Attached Thumbnails How do I convert my 06 silverado from DBW to Cable drive?-sdc10383-1.jpg
Old 05-05-2010, 08:26 PM
Excellent! Now I wonder How hard it is to swap pedals and add the cable, is there a provision cable going through the firewall?
Old 05-06-2010, 04:41 PM
Noah Burns's Avatar
the pedal swap isn't hard, it's just a pita to crawl up in there and move everything around and find the bolts etc. not "hard" just painstaking.
Old 05-06-2010, 05:52 PM
1Bear's Avatar
The issue with the 102mm Nick Williams unit pictured is that it is designed for a Vette or CTS-V thru '04 and could also be used with the electronics from an '01/'02 model truck that was equipped with a DBW throttle, hence the strange looking to the newer model crowd throttle body motor and separate TPS sensor.
They do offer a conversion harness to use the older style throttle body on a '05 and up Vette, but I don't know how it would work on a '03 or newer truck.
Quick Reply: How do I convert my 06 silverado from DBW to Cable drive?
