How do you reset the PCM after cleaning MAF?
Old 08-22-2005, 09:42 PM
FormerVendor
KLUG'S SS's Avatar
Originally Posted by OKLAGMCRUISER
ECM reset is as follows:
Key in on position
pull ecm1 and ecmb fuses
wait aprox 5 minutes with key on
key in off position
replace fuses
start vehicle...it may run rough a bit at first for a few seconds.
Pat
I never knew that there was a reset procedure like that, I was just always told to disconnect the battery for a few minutes and that would do it.
Very good to know this I guess that would explain why I couldn't get my SES light to go out from just undoing my battery cables.
Old 08-22-2005, 10:45 PM
14 Second Truck Club
JERRY2500's Avatar
Originally Posted by makoshark
I did clean the MAF with the electric cleaner.
Was it the one without the lubricant?
Old 08-22-2005, 11:12 PM
Banned
makoshark's Avatar
I`d have to look, but if I`m not mistaken it was the one with the lube.
Old 08-23-2005, 05:29 AM
JERRY2500's Avatar
Need to get the one without the lubricant and clean it again. You just coated your MAF BTW you should get your Injectors today.
Old 08-23-2005, 06:00 AM
Moderately Differentiated
dewmanshu's Avatar
i have used just alcohol and q-tips before as well...just be very careful with the qtip. But using the non-lube electra cleaner works great.
Old 08-23-2005, 10:39 AM
OKLAGMCRUISER's Avatar
i was told that disconnecting the battery on the 99-05 trucks does nothing but reset the clock on the radio...hehe.
Old 08-24-2005, 07:09 PM
Banned
makoshark's Avatar
It helps to remember to plug the MAF back up once you clean it. That`s what I did. Thanks for your info guys
ChristianSilverado (08-01-2020)
Old 08-24-2005, 10:04 PM
JERRY2500's Avatar
lucas287
31
01-12-2021 06:18 AM
97gmc
22
09-08-2015 10:56 PM
Pimpinpete
09-08-2015 07:39 PM
muncie21
09-07-2015 09:55 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
Quick Reply: How do you reset the PCM after cleaning MAF?
