How many are running 2 bar SD?
LS1TECH Sponsor
Applying a 2 Bar SD Enhancement
Here is the demo to apply 2bar in HP Tuners.
Note the boost enrichment table.
The proper way to tune the vehicle with a boosted vehicle is to use both PE (non boost load) and the boost enrich table for boosted regions.
This is also very useful for turbo vehicles that do not generate boost instantly and need to spool up.
- Keith, HP Tuners
- Keith, HP Tuners
- Keith, HP Tuners
- Keith, HP Tuners
How do I change this text
- Keith, HP Tuners
- Keith, HP Tuners
Thanks for the info.
Now I just need to find some one that sells the MAP sensor.
Well I just got my MAP sensor installed, and did a log but the map doesn't go any higher than befor. Do I have to make a custom PID or something?
LS1TECH Sponsor
Make sure you insert the 2bar MAP PID in the scanner and remove the SAE one.
Also remember you want to still use both the PE (Power Enrich) AND the BE (Boost Enrich) tables. They each have their purpose.
