How much timing?
Old 02-17-2008, 10:01 AM
dirt track racer 81's Avatar
Originally Posted by dewmanshu
Interesting. I've messed with a couple stocks and I like 24-26. No kr and it felt strong enough that the driver was happy. 91 in your area shouldn't suck that bad I'd think.
thats what im thinkin..i wonderin how in the hell some people can get alot more timing and not knock..i always keep 110 mixed in with my tank though..i dont trust pump gas and i dont like sprayin on pump gas
Old 02-17-2008, 11:46 AM
Banned
Klive's Avatar
i'm wondering why so many guys don't just turn their knock sensors off...WAY to much false knock to worry about
Old 02-17-2008, 11:51 AM
i did along time ago when i was running 10 degrees and sayin i had knock and thats with some 110 in it
Old 02-17-2008, 12:14 PM
Banned
my stock truck took about 27deg anything higher would cause kr
Old 02-17-2008, 12:51 PM
Banned
Klive's Avatar
they're still on in my truck, only because i haven't tuned it yet (hpt will be here Monday) but on my camaro they were off from day 1.
Old 02-17-2008, 01:28 PM
cmitchell17's Avatar
Without a dyno for timing, im so demorilized on timing. Nothing really makes sense and there is nothing you can really trust for good timing (besides factory timing)
No matter what I do with my timing it makes no diffrence I can detect on my 5.3 with headers.
If you have a cam timing should be increased at low rpms as ve isnt as high at low rpms with a big cam, but as rpms rise ve will go up with a big cam and the engine wont need as much timing.
The optimal timing on the vortecs is about the same on LS motors, which I would think the vortecs would require more avarage timing becuase of the slightly lower compression ratio.
Anyway the optimal timing (what the pcm uses to calculate torque based on how far the acutal timing is away from it) for the 5.3 it about 28-29 @ 3600.
For as much testing as the factory does to thier engines I guess you can trust that the optimal timing in the factory tunes is the optimal timing. Trust 27-29degrees of full timing at wot, although it might require a higher octane fuel.
For headers, I havent seen any diffrence from them. I don't see any diffrence in airflow either.
Old 02-17-2008, 09:48 PM
TouchOfEvil04's Avatar
i'm running 27 and let it climb up to 29 at high rpms. no knock at all on my bolt on 5.3l truck.
Old 02-17-2008, 10:11 PM
truckmann's Avatar
I was running 27-28 at WOT on the stock cam without KR. I had problems when I originally started tuning getting the timing up much, but after I got the fueling nailed down better I had no trouble running more timing.
Old 02-17-2008, 10:16 PM
how are you guys getting your fueling nailed down without a wideband?
Old 02-17-2008, 10:21 PM
Resident Retard
BlackGMC's Avatar
I run roughly 28* with just boltons and a 4.8... I don't get any KR.... IMO start out with a richer mixture to get the timing you want the adjust your AFR accordingly.... I have got my AFR spot on while it SD mode but when I enable my MAF and tune it it seems like I have less power.... Next weekend I am going to covert over the COS3 and be done with the MAF..... Do timing is slow increments...
Quick Reply: How much timing?
