HP Tuners Noobie, unable to tune VE
Ok, I just received my HP Tuners Pro, and have read many tuning 101 procedures, which say to start with VE tables(LTFT/STFT). But when I disable my MAF( set freq. to 0 and disable ses light for P0101,02,03 ) my truck barely runs at all, just kinda sputters and dies even giving it some gas. Is there something I'm missing? I reset fuel trims and turned fuel trim learn on. I think my stock, or default table is way too lean. I'm installing my WB Sunday, but my stock O2 voltages were at like 200-400. I'm going to try and post up a log. Any direction would be very helpfull, I've read and read, but havent seen this issue addressed. Thanks in advance. ( That is my stock Scan with MAF enabled, I'll log tomorrow with it disabled again and post it )
Moderately Differentiated
Using the STFT corrections only from the scanner histogram data
This will require you to disable the LTFT process.
Use of this method requires your VE table to be no more than 10% off. If your VE table is beyond this, start with the LTFT method first.
Depending on your model you can either turn the LTFT enable option to “Off” or set the LTFT minimum Engine Coolant Temp (ECT) to its maximum value. Yours you'll need to change the "minimum" over the right hand side of the fuel OL/CL tab. When you are ready to start the scanning process to record the histogram data, use the VCM Controls function to reset the fuel trims.
This will let the VCM run the STFT correction, but no make any LTFT corrections.
The advantage to this is you only have to use the STFT table on the histogram to get your fuel % correction values. You no longer have to do the (+-LTFT %) + (+-STFT %) math or keep track of the LTFT cell number in use.
This will take you about ½ the time to log the STFT, make the corrections to the VE table, then verify the results on the histogram again.
Your corrections to the VE table cells are the +-% STFT error.
Again, a motor is considered well tuned to have STFT values between +- 4%. Not every motor can achieve this though.
Don’t forget to re-enable the LTFT when you are done.
Table Smoothness
As vehicle conditions change the cell in use of the VE table will change. A smooth VE table will help vehicle fueling transitions. A choppy VE table will cause irregular fueling.
When making changes to the VE table, try to modify surrounding cells as well to help preserve the flow of the VE table. It is unlikely for close operating ranges of your engine to vary drastically in volumetric efficiency and thus your table shouldn't either. Transitions over cliffs, ridges, spikes and other erratic data of your VE table can cause less than desirable results.
Good VE Table
Bad VE Table
All from the help file, except the "yours" an bold underline stuff.
Table Smoothness
Good VE Table
Bad VE Table
Ok, I opened up RTT and added 15 to all the cells from 400-3600....little better. So I added another 15 to those same cells... Idle was much better, almost like stock tune with the MAF enabled. So I started my Log/Edit VE process while watching my O2voltages and saw more 700-900 ranges. Saved data, wrote cal, and re-log/edit smoothing out the graph each time i paste. I think I'm headed in the right direction (finally) so I'll continue this process until I get it dialed.My FT have gone from about -+ 30 to -+12 . In the mean time, I'm not even going to turn my laptop on, or scan for the rest of the night because I'm going crazy So I think I'll
Resident Retard
Mine idled wierd once I start VE tuning, but after a little bit it idles better. Stick with it man, learning to tune is a little frustrating at first, but after you figure things out and ask a ton of questions it gets easier...
Oh, another thing I did was merge the optimum timing table with my High Octane table and smoothed it a couple of times, it gave a decent improvemet for starting timing tunning.
LCHEE
10-24-2020 04:10 PM
mr03silverado
06-26-2016 06:05 AM
