hpt tuners and wide band connections???
Well I have hpt pro and recently installed my fjo wide and guage. Where on the box do i connect the wide band to? there are several spot to plug wire into just not sure in what spots they go to? I would like to start logging my a/f with this.
Did you check the help files? It is clearly explained in there with diagrams.
http://www.hptuners.com/help/vcm_sca...connecting.htm
Connect your signal wire to pin 1. Connect your ground wire to pin 5. Open Scanner application and go to Table Display. Right Click on EIO Input 1. Select Insert. Click on Wide Band O2. Select Wide Band O2 - FJO. Save Configuration. Hook up to truck and verify you can log Wide Band signal. You should be set...
Bill
(edit) Here is a pic of how I routed my WBO2 wires...
Bill
Im also wondering if I can do it a different way. The fjo wide band came with a serial port. I wonder if I can just use that to connect to instead? Or if that is only for the software that came with the WB? I guess i'll just have to try it a few different ways.
muncie21
09-07-2015 10:55 PM
