HPTuners
Formerly Low_LQ4 - 6/6/10
Originally Posted by regency
thinking of buying the program, but i dont even know what im getting into. how do the credits work? everytime you update your tune or just change something in the tune does it use a credit? hows it work????
LS1TECH Sponsor
Originally Posted by dmc_racer
It takes credits only once for your truck, it doesn't take credits when you change the tune, it takes time to get used too am not 100% sure of everything because am new to this two but am doing my best and the truck is running hope that helps.
$499 for the Standard Version
$649 for the Pro Version, which inlcudes stand alone logging and Ehance Input/Outputs for logging such items as a wideband.
With both you get 8 credits to use as you see fit. So for you case, you would use 2 credits for your truck and 2 credits for your Father's street rod. That leaves you with 4 credits to use for enabling RTT on both vehicles, or using the 4 credits for two more vehicles, or 2 credits for 2-BAR OS (in case one or both of you want to add boost). Many possiblities.
RTT = Real Time Tuning
No extra hardware required, and it is very powerful when you want to make changes on the fly to tune either the fuel maps, idle control, or knock and Stock O2 switch points.
