HPTuners - What else?
Hi all, going to be purchasing the HPtuners VCM Suite Pro version, is there anything else I need? I am planning on hooking up a wideband, do I need to get the plug (MPVI Pro EIO)?
TIA
TIA
If you get EFILive V2 cable, and a LC-1 WB, you can plug the serial out put form the LC-1 directly in to the V2 controller and log serial WB data instead of just analog. The V2 will also display the current WB reading right on the display screen. It's a very nice setup. I can hook you up with a package deal if you like.
It has been suggested to stay away from the Innovate stuff, so far looking like the NGK AFX.
Apparently there are (were?) issues with the LC-1 and LM-1s? Do you have any other suggestions recommendations?
Edit: Thanks for the offer KB, already ordered the Pro via HPtuners.
no voltage offsets with serial cable. If i could do it again i would do an lc-1 and plug it into efilive. My analog works ok, but always reads a bit different than my serial gauge that in the truck. Which makes fixing the ve table a pita...
I'm using PLX SM-AFR. It has a box mounted under the hood that is the actual WB controller. You can use their AFR Gauge, or their OLED displays to show the data along with the 0-5v analog signal.
Porscharu914
14
01-20-2016 10:45 AM
legerwn
56
11-15-2015 10:21 PM
