I own HPTuners. Who can do an email tune for me?
Hi guys. I just finished my 80E/3K stall/AWD swap in my 2000 Silverado. I'm running my stock 5.3L. I got a segment swap done and have played with the transmission tuning. I think I've got my transmission about where I want it.
The only thing my truck has, performance wise, is a cold air intake, shorty headers, cat back exhaust and LS1 e-fans.
I'm looking for a 91 octane tune.
Yesterday I ordered a NX Proton Plus nitrous kit. Hopefully, I'll be installing that in the next few weeks. (To tide me over until I have the time to assemble my 6.0L turbo setup.)
I'm going to start with a 50hp jet and play with n2o. I've read quite a bit and everyone says that you can safely run 100hp shot with a factory tune. I figure after I go through the first bottle or two, I'll move to 100hp. Then go to 150hp and try this mod out.
https://www.performancetrucks.net/fo...ptions-454692/
I'll have to figure out the HPTuners version.
Anyway, can someone hook me up with a conservative 91 octane tune?
I believe this is my most current tune.
https://www.dropbox.com/s/34rx32nurd...ns%20tuned.hpt
I haven't had time lately to sit down and mess with HPTuners. I really want to, but there's been layoffs at work and tons of overtime covering said layoffs. I'd really like to see someone else tune so I can read, compare, and learn.
I'm not sure who to go to with this. Who will do a "mail order tune", but through email? Who's reputable?
Thanks in advance. I really appreciate it.
![Cheers!!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_cheers.gif)
Attached a file which you can learn off of. T You might find the tow/haul settings a bit interesting if you haven't seen it before. It will allow you to do roll racing while staying in the gear which keeps you in the powerband. So in short, the tranny does not shift until WOT and behaves like a manual transmission somewhat.
Attached a file which you can learn off of. The timing is good for a 100 wet shot, if no nitrous then you can add 2 degrees of timing after the .60 g/cyl area and down. You might find the tow/haul settings a bit interesting if you haven't seen it before. It will allow you to do roll racing while staying in the gear which keeps you in the powerband. So in short, the tranny does not shift until WOT and behaves like a manual transmission somewhat.
I'm at work right now, I posted this whole thing from my iPhone. I can't wait till I get home later tonight to try it out!
Okay, I'm a bit confused. If I load this on to my truck is it okay to run without nitrous? Are you saying to only load this tune if I plan on spraying immediately? My nitrous kit won't be here for a few weeks, should I add the timing back?
While my truck isn't my daily driver, I need to act like one. I sort of need it to be wife proof. LOL
I can't wait to get home and check out the tune, I wish I could bring my laptop to work and learn on my breaks. LOL.
EDIT:
LOL. I wrote this whole thing out then you edited your reply.
Long story short, can I run this tune tonight? Can I run this tune with 91 octane and up to 100 shot of n2o?
Seriously, thanks again you guys. Your help means a lot.
Thanks man. I really appreciate all the help I can get!
Dude, you hooked me up with a tune! You're awesome!
EDIT:
EDIT:
![Shiftin' Fool](https://www.performancetrucks.net/forums/images/smilies/3.gif)
