IAT's
#34
Please help me guys! Is the stock IAT sensor built into the MAF? If so which two wires do I need to use? There are 5 wires if I am correct? I believe I need the tan wire and one of the two grounds. Is this correct?
#39
Former Vendor
Exactly, I would much rather see real temps than lower how much the PCM pulls. Although running that high a temp might not need that much timing removed. I would have to run those temps and see how much timing it needs and adjust those tables. But that would require a lot of work on the dyno with no fan in front to try and get my real air temp in that range or put a blow drier in the air stream, lol.
dantheman1540
09-18-2015 03:03 AM
TAPyvehc93
09-17-2015 10:10 AM
