idle issues
idle issues
I have a 2005 GMC sierra it has a procharger with a custom dyno tune.
every time the battery is disconnected the truck has major idle problems. i understand that the truck usually search for idle but it is searching from 200-1100 rpm and will some times stall out. it has done this before and after a few days of driving it finally fixes itself. tuner says nothing is wrong. please help
Sounds like your base idle airflow wasn't tuned for all your modifications. Like Andy said, the fuel trims are reset when the battery is disconnected. But along with fuel trims, the idle trims are reset as well. That means it has to reference your untuned idle airflow table which is way off. After some driving time, the pcm will learn how much airflow is needed at idle in drive and park. Your idle trims will add/subtract airflow from your base running airflow table to keep the idle rpm stable. Find a different tuner because it is very easily fixed.
smokeshow
08-23-2015 08:23 PM
05GMC4.8
08-07-2015 09:55 PM
GMCtrk
07-17-2015 06:39 PM
GreyChevy
07-07-2015 08:57 PM
