Idle RPM's & Trans tables
#21
I have a gauge for that
rockauto has some good prices for sensors... as far as I know the front and rears are NOT the same...tried it once and it didnt work correctly. I would switch them left to right (fronts) to check for a faulty one, if the unresponsive one moves to the other side when you switch them you found your problem.
#22
11 Second Hall Moniter
Sorry Richard, but this is FALSE. They are infact the exact same part number. It is possible, that you had a bad rear sensor also, and swapped it into the front, and still had problems. I've swapped them for people in the past, and it works.
Here's CarQuest's dealer catalog, upstream and downstream are the same part. I'll be deleting these pics in a few days since they show dealer pricing...
Tom, swap the sensors, like we talked about. Save your cash. Turn off the rear 02's in your tune, swap the bad sensor to the rear. It will be just fine.
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
lxcoupe
07-14-2015 10:14 PM
GreyChevy
07-07-2015 08:57 PM
