idle tuning iac position 0
Old 12-30-2012, 08:54 PM
Custm2500's Rude Friend
1FastBrick's Avatar
What year is the truck it self???
Old 12-30-2012, 09:06 PM
kelsey_canard's Avatar
Just went out and checked...truck has a pcv valve
The truck is a 99. Not sure what year the motor is.
Old 12-30-2012, 09:08 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Sounds like a vacuum leak somewhere. What's your MAF grams/sec at idle, engine hot?
Old 12-30-2012, 09:25 PM
Dont have a current scan with the maf logging. My other scan shows a map reading of 48-53kpa with 29 degrees of timing. Way too much timing and the map seems a little low to me.
Old 12-31-2012, 06:10 PM
gagliano7's Avatar
That hole in throttle body is stock.Sounds like you have a vacuum leak.
Old 01-02-2013, 11:52 AM
Sprayed the intake down with Carb clean and found vac leaks at the egr port, tb, and cylinders 6 + 8. Going to swap intakes and try everything again. I'll let y'all know how everything goes.
Old 01-02-2013, 08:43 PM
Well, got the intakes swapped and it cleared the problem up. Thanks for the help everyone.
Old 01-02-2013, 10:37 PM
Good to hear!
tweeder
09-18-2015 11:02 PM
fillpot
07-26-2015 07:21 PM
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
GreyChevy
07-07-2015 08:57 PM
Quick Reply: idle tuning iac position 0
