Injector Swap Tuning Help! - HPtuners
So i have new injectors coming planning to put them in friday. What do I have to change in hptuners (i'm new to it) to get these things to work?
Here are the specs on the injectors:
Delphi Multec 43# injectors Part # 17113739
Static flow @ 37.95lb/hr @ 43.5PSI / 300KPa (4.31 g/s = 398cc/min)
Static flow @ 43.82lb/hr @ 58PSI / 400KPa (4.97 g/s = 460cc/min) *
Dynamic flow (2.0ms/10.0 ms(pulse width / rep rate)) 6.0 lb/hr @ 43.5PSI (0.748 g/s @ 300KPa)
Coil Resistance: High Impedance / High-Z (No ECM driver modifications required)
Ball/Seat Design with 3-Hole Diffuser Disc - Pencil stream
any help would be appreciated.
All I changed with my 31#'ers was the IFR table.. Just need to find the flow rate and enter it in the IFR table.. I am not sure if you have to scale yours on your model or not.. Mine was the same number all the way across the board..
mzoomora
01-03-2016 07:06 AM
GrooveCityZ71
08-31-2015 12:05 PM
oharajo
07-18-2015 09:24 PM
