innovate wideband question
Old 11-16-2010 | 08:50 AM
Gadgetized's Avatar
Default innovate wideband question
I have an Innovate wideband that I have used for about 2k miles. Since installing my new exhaust and tranny it works for a couple miles, then starts flashing. It flashes in a 4 flash sequence. I am 100% certain that it is heating up, but I am not sure why it works, then stops. Does anyone know why this is happening?
Old 11-16-2010 | 10:21 AM
smokeshow's Avatar
Mod with training wheels
Is it just the wideband or do you have the gauge too?
Old 11-16-2010 | 10:49 AM
Gadgetized's Avatar
Just the wideband. I am running it with EFIlive, and can see that it is initially working.
Old 11-18-2010 | 07:42 PM
Mort's Avatar
The four flashes mean error 4?
Error 4 Pump Cell circuit open - 1. Damaged sensor cable or sensor connector not fully seated. Verify sensor connector is fully seated into unit. If yes then Repair/Replace cable.
2. Sensor heater calibration incorrect. Perform complete heater calibration (not just free air calibration) See section 4 of manual.
Sounds to me like your sensor is heating up but not calibrated properly.
If that does not work you may need to replace your sensor. Mine would read when I started up the truck and then quit, but I got eight flashes or sensor timing error. Performed a heater recalibration and free air calibration and it still did not work. Put in a used sensor I had saved and it works great.
andrewlong
11-09-2016 10:38 AM
Forcefed81
09-08-2015 11:02 PM
2004gibbstruck
09-07-2015 07:05 PM
iregret
09-07-2015 02:20 PM
madmann26
09-06-2015 05:19 PM
