installed long tubes now o2s not working
Old 09-01-2009, 08:31 PM
droppedchev's Avatar
Default installed long tubes now o2s not working
i just installed long tubes with 3 in y pipe yesterday i took my truck out today and i got a check engine light now saying bank 1 and 2 o2 sensors not working are the sensors dead or should i take them out and clean them and see if that works from all the stuff burning off inside or is the senors bad
Old 09-01-2009, 08:33 PM
TXsilverado's Avatar
you need to have your tuner delete your rear o2 sensor codes. they just tell if your converters are working correctly
Old 09-01-2009, 08:46 PM
its sensors 1 the rears are already deleted sorry i forgot to mention that
Old 09-01-2009, 09:18 PM
norris_83's Avatar
theres no way they'd die within a day.... they're either not connected up properly or the harness has been melted along side the headers..
Old 09-01-2009, 09:21 PM
GMCtrk's Avatar
they might not be heating up properly
Old 09-01-2009, 09:25 PM
i checked there hooked up i unhooked them and hooked them back up and there not even close to touching the header truck has 105,000 i think there orignal
Old 09-01-2009, 09:26 PM
it comes up saying that neither o2s are working im going to try to pull them out and clean them see if that does it
Old 09-02-2009, 11:22 AM
blackjack325's Avatar
did they get banged up during the install??
Old 09-02-2009, 11:28 AM
Wearin' da big hat
00ChevyScott's Avatar
swap the ones that were in the back up front assuming they have the same connector. Mine were the same and when one died I just threw one of the rear ones up front.
Old 09-02-2009, 12:45 PM
JakeBrakeIH's Avatar
my 2000 had different connectors, but you might get lucky and do what scott did
Quick Reply: installed long tubes now o2s not working
