installed some long tubes..
Originally Posted by 01 Thunder
well I havnt even been able to drive..
it's just the headers.. tomorrow I am going to get the rest of the exhaust put on...
12 Second Club
Originally Posted by rgvsierra
ahh, lol, if you are running open headers thats the cause, i ran open ypipe for a bit and my ltft were off too.
i just didnt want to drive it to the shop in the morning if it was going to cause problems..
it sure doesnt want to idle for nothing tho...
I hope that changes once I get the exhaust finished.
mine done that too
the O2s are so close to air it makes it think its lean
so you are extremely rich ...but not rich in the good way LOL
you'll be fine
if you can, clamp some extensions on so the o2s arent reading all that clean air
you'll be fine
sorry if I didnt make that clear to start off with..
Originally Posted by 1slowsilverado
I had the same problem, Not with the trims but with the 02 sensors not switching. Are your headers uncoated? I had to go with a different 02 sensor and swap the pig tails to be a direct fit.
Arise dead thread 1slow, what kind of O2's did you end up using? I have heard the rear vette sensors will work. Im wondering about the rear Camaro sensors.
My fix was the downstream Vette sensors, Bosch 13111's. I had to swap the pig tails as it was not a direct fit for me. Problem was the stockers were to exhaust temp dependent and my headers dissapated to much heat causing the 02's to switch VERY slowly. The Bosch 13111's have a better heater element and are not as much exhaust temp dependent as the stockers.
Im not sure about the F-Body cat sensor? Thoes guys that have a problem use the Bosch 13111's also. I dont know if its cause the heater is better or they just need the cable lengh as there downstream is to short to use as a upstream sensor?
Just for search purposes ... you can unplug the front o2's and drive all you want with open headers.
With open headers, the fresh air comes back in and hits the o2's making the PCM think it's running very lean, thus dumping more and more fuel, resulting in +25 ltrims and low o2 readings.
