installing power windows with switches on the center dash
someone double check my ****.
i'm using the same concept for the power locks.
i'm putting momentary toggle switches on the dash just above the passenger airbag indicator. one for the left window, one for the locks, one for the right window. then i'll hook it up to an aftermarket alarm/entry system.
8 Second Truck Club
take the key out.
The power for the DPDT switch can come from a switched 12v source.
Here is a set of arm rest I'm doing for a member on here. He wanted to get rid of the bcm so...
started with this:
ended up with this:
Here are the arm rests with the switch housings and carbon fiber installed:
Here are the ones I did for my truck:
started with this:
ended up with this:
ARC
57
02-21-2022 10:54 AM
HIDEXTRA
07-21-2015 05:43 PM
atxlt
07-20-2015 11:06 PM
Offroadunleashed
07-20-2015 02:25 PM
