Interpreting LTFT #s
Trying to figure out positive and negative LTFTs here. If the LTFT #s are positive, does that mean that the motor is lean and the PCM is having to add additional fuel?
Could an old O2 sensor (190,000 miles) cause this? Could the old O2s also cause a P0174 (lean bank #2) DTC?
'96 Chevy Blazer, 4.3L "W" motor.
LS1Tech Sponsor
WOW you got alot of miles out of that sensor. I believe i read in the tech docs for the sensors being used and they start to degrade after 30,000 of "NORMAL" use. When and if they die obviously depends on driving habits and quality of gas being used. I try to replace all mine at 40,000 miles just to be safe. The slower they get the more they hang on the rich or lean side while switching.
creekrat
09-10-2015 12:59 AM
smokeshow
08-23-2015 08:23 PM
Fast86z
08-23-2015 12:35 AM
mbrownlee
04-30-2009 07:42 AM
Zick
09-23-2005 10:38 AM
