keyless entry not working
Old 01-13-2013 | 06:44 PM
Gadgetized's Avatar
Default keyless entry not working
I have a 99 Silverado with 174k on it. It is my daily driver and quite beat. A few months ago my keyless entry stopped working. I thought it was a dead battery, so just figured I would get around to buying one. Well I finally remembered to get one and it didn't fix the problem. I have another remote that has very little use on it, and that one doesn't work either even with a new battery. Does anyone have any ideas?
Old 01-13-2013 | 07:16 PM
On your unused remote try holding down the lock and unlock buttons at the same time for 20-30 seconds it will respond by honking horn and locking and unlocking the doors. Put a new battery in it first.
The above procedure is called a re-synchronization procedure to match and reset the rolling code algorithim between the bcm and the RKE remote.
Old 01-13-2013 | 07:43 PM
Gadgetized's Avatar
It works now. I put another battery in the remote I never use, and it worked for some reason. I tried the remote I used to use, and it didn't work. I did the re-synchronization as you suggested above, and now they both work. I thought for sure it would be a rusty connection somewhere. Thanks a lot.
Old 01-17-2013 | 11:05 PM
No problem
chopperloco
07-10-2016 10:45 PM
Stainless Works
04-10-2016 04:34 PM
Stainless Works
08-04-2015 12:56 PM
Bluecollar Hotrods
07-26-2015 09:56 PM
atxlt
07-20-2015 11:06 PM
Quick Reply: keyless entry not working
