Knock knock.... who's there? KR
#21
Originally Posted by dewmanshu
jim change that filter to stock. (4.7) And get some scans.
your on your own with the trans questions.
i am going to change to 4.70 and rescan. Just wanted to see if anyone knew if my setting was more or less sensitive than stock. As far as the tranny stuff, i was just seeping thoughts. I dont expect for anyone to really know those questions. I figure there are not a whole hell of alot of people with the 8.1L/Allison with EFILive doing any custom tunes or logging. If they are, they either have not got any further than me or they aren't talking....LOL. I have come to grips that alot of this stuff is going to be trial and error for me, but it never hurts to ask first i suppose. I am just not knoweldgeable enough with EFILive to feel comfortable changing stuff without really knowing what it is first.
#24
Hello Dave
Originally Posted by Whippled 496
Agreed,
Seeing as how ALL other trucks have 4.7, I see no reason for yours to be different, give it a try and let me know.
Justin
#26
Hello Dave
Originally Posted by 02sierraz71_5.3
different block
I've checked both Iron and Aluminum block tunes, all different years and sizes, and haven't found anything but 4.7 as the filter value.
#27
One thing you might think about trying that was a problem for me, is I used to get a lot of KR when it when going from vac to boost. I read on EFILives forum that setting all the engine torque management values to max would fix this. I tried it and it seemed to work. Something to try anyway if you haven't allready tried it.
#29
Originally Posted by dc_justin
Jimmie, when you open up B6227 on your tune, does it pop up with a "List index out of bounds" error? Any changes I try to make to your 7.9 value don't take...
Justin
Justin
if it was set on 7.90 and you "-1", it wont go to 6.90...it will actually go to 4.70. If i "-2" it would go to 2.50. Very odd, but i got it to save without errors. I will Email the file to you.
#30
Hello Dave
Justin, i have not written it to the PCM yet, but it saved fine for me. What i did was highlighted all the values and put a "-1" in the "adjust" box, then hit the "+/-" button and it worked fine. Whats wierd about that table is when you increment by "one" it doesnt actually increment the data by "one unit". When you "+1" to the data, it actually just steps up to the next available option.
Strange. I can get it to change to 4.7, save it, then reload and it is back at 7.9, all fields are yellow and I get an error alert. Maybe the file I have is corrupt...
