knock sensor help please!!!
Old 06-07-2007 | 06:28 AM
beastmode's Avatar
Import Moderator
Default knock sensor help please!!!
this is one of 2 of the only problems i have so far (other being ABS light)
this is the code it throws, sometimes its constantly on, every once and awhile it will flash for a little then go back to constant... then sometimes it will even shutoff then later when i start the truck back up it will be back on???? im sure it can be a number of things but i wanna get like a list of the things it can be and start checkin em off one by one. i already took the manifold back off and made sure the knock sensors were plugged in, and that they were plugged into the harness properly. any help would be appreciated guys. TIA
Module: 10
DTC: P0332
Type: DTC
DTC Description: Knock Sensor (KS) 2 Circuit Low Frequency
Old 06-07-2007 | 08:07 AM
SSSBLKOUT's Avatar
I don't know if its any help, but I got a code a few weeks ago for the same thing (I think mine said "KM circuit, low voltage). I bought some KMs and the harness off ebay, was getting ready to put them in, and the code went away . People said that would happen if they got a little wet, which i guess is what happened. I scan it every now and then, and the code is gone???
I still have the modules and harness (5.3L but I don't think theres a difference between models) if you want them. Let me know.
How long has this code been popping up?
Old 06-07-2007 | 08:20 AM
vandy1821's Avatar
the same code happened to me a year ago the day after i power washed my engine it came on the knock sensor in the rear has been holding water for a while an dshorted out
Old 06-07-2007 | 08:32 AM
beastmode's Avatar
Import Moderator
since i did my LS1. you have the harness and both modules then? ill take em. if both of you guys had the water problem maybe i do from doin the swap, maybe something got in there, might as well give it a shot
Old 06-07-2007 | 10:27 AM
Nick™'s Avatar
I'm willing to bet that you crushed the knock sensor wires under an intake runner. White1 and DLH2006 both had that issue, it's very easy to knock that harness under there when installing the intake manifold
Old 06-07-2007 | 10:31 AM
beastmode's Avatar
Import Moderator
ya that could be it to, i thought that foam was there so you dont crush it. i might have though, either way i am replacing the wire and sensors this weekend. ill keep you posted, thanks for the responses
Old 06-07-2007 | 12:47 PM
Nick™'s Avatar
that foam just kinda seals up the cavity, but the problem they had was the wire actually was between the manifold and the head, like crossing the path of the runner, just pulled the intake manifold and a quick splice of the wires and it was working perfectly fine.
Old 06-07-2007 | 12:49 PM
beastmode's Avatar
Import Moderator
o ok i see
ya i figure ill just replace mine just to be sure, i dont wanna have to take my manifold off again... its not hard, just a pain in the *** since i have to do it in a sloped driveway
Old 06-09-2007 | 12:23 PM
Mark Johnson's Avatar
Cool. Well allow me to post my comments and compliments. That's a very sanitery looking setup, the whole truck as well as the engine. I'm gonna start monkeying around with my truck in the comming months. Nice work, a real sleeper fer sure..........
Old 06-11-2007 | 06:55 AM
beastmode's Avatar
Import Moderator
thanks dude
bump for this, changed the harness and the sensors and the code is still going. i dont know what it could be. im gonna check the actual wiring harness itself and see if anything is wrong wit it but if anyone else has input id appreciate it
tia
Pimpinpete
43
12-22-2017 09:13 AM
bearden86
26
11-15-2015 04:58 PM
JordanH
10-03-2015 04:59 PM
trevorh1
09-27-2015 09:47 PM
WICK3DxGATA
09-24-2015 07:56 PM
